HV Battery Draw Down Sequence
schaffer9
CA
2023 Mustang Mach E
Just curious - How does the HV battery (NFM) draw down as the car is used? Do all of the cells draw down equally or do they draw down in groups? If in groups, what are the voltage & wattage of each group?
The extended range pack has 72 amp-hour cells arranged in a 94-series 4-parallel configuration. Yes all the cells are discharged equally and remain at similar voltages relative to each other.
schaffer9
CA
2023 Mustang Mach E
Thanks for your quick reply.
Gimme_my_MME
Dearborn
Regardless of your chemistry or pack size, if the cells start deviating to much they will throw a fault
