I-Pass Sticker in Illinois
cwpyne
Charlie
Chicago
2023 Mustang Mach E GTPE
I have a 2023 GTPE and just got the new Illinois I-Pass Sticker. As instructed I put it on the windshield under the rear view mirror. It doesn't work. Has anyone else had success with this new sticker? If so, where did you put it?
GreaseMonkey
Chicago, IL
24 Mach-E GT
I don’t think I’ve seen a sticker. Can you post a pic? The transponder works great.
As instructed by who? Ford's instructions are to put it on either side of the rear view mirror in the back dotted area.
GreaseMonkey
Chicago, IL
24 Mach-E GT
It might still not work. The sticker has a barcode that might need to be visible (not sure, though cause this is very new). This change appears to be coming to the rest of the country.
Oh, it's optical? I just assumed it was an RFID type sticker. But I don't live in Illinois.
GreaseMonkey
Chicago, IL
24 Mach-E GT
I don’t know. I live in Illinois, but have the traditional bulky transponder. This change happened in Jan this year. Here’s how it looks:
Ford Mustang Mach-E I-Pass Sticker in Illinois IMG_2998
Jeff-NoVA
Jeff
Northern VA
2022 Mustang Mach-E Premium
Transponders don’t go under the rearview mirror. They go on either side in the area with the dot matrix.
GreaseMonkey
Chicago, IL
24 Mach-E GT
Ok, the new tags use RFID. @cwpyne , you should be able to get it to work if you put it in the spot designated by Ford (on the black dots near the mirror. Pls try and report back.
cwpyne
cwpyne
Charlie
Chicago
Good idea. I'll try that. Have to get a new one this week, caus they fall apart when you remove them.
AlMelbourneFL
Al
Melbourne, FL
2023 Mach E
Retired s/w developer
I had a similar problem with the sticker that’s used to get into my subdivision. My sticker is very narrow. The installer ruined a couple stickers and then solved the problem by affixing the sticker to the top of the headlight. It did not affect the lighting in any way.
Fremont Kid
Colorado Springs, CO
Retired IT
I hope this helps. The area behind and on each side of the rear-view mirror, i.e. which has the dark dots, is not coated with a material that interferes with the transponder RFID signal. The rest of the windshield is coated.
Cameras may not be able to photo-read (my term) a bar code through the dark spots, whereas an RFID reader could receive the RFID signal.
cwpyne
cwpyne
Charlie
Chicago
Just picked up a new one....put to the right of the rear view mirror in the dot matrix area and it worked! Thanks for the help....
