Michigan Improving winter driving range
katracy
Keith
Sawyer MI
2024 Mustang Mach e GT
I just got my 2024 Mustang Mach e GT on Saturday. Our garage stays at about 45°. The car is connected to a 240 outlet overnight. Noticed that the available drive range at 100% was around 220 miles this morning. I used the FordPass app to warm up the cabin and I thought maybe the battery as well but I only noticed a couple miles increase In the available range. Is there anything I should be doing to improve the number of miles I can drive on a charge in the winter when storing in a heated garage? Thanks!
hybrid2bev
2026 Rally
Congratulations on the purchase.
1. Read your owners manual
2. You have an extended range battery so don’t charge to 100 unless you need it (see #1)
3. Use a Departure Time while plugged in to warm the battery (see #1)
4. Climate on from FordPass only heats the cabin (see #1)
5. Ignore fluctuations in the GOM (see #6)
6. Read this. https://www.macheforum.com/site/thr...lanation-how-to-calculate-actual-range.13749/
7. See #1.
AKgrampy
Fairbanks, Alaska
You may not get much additional range preconditioning your battery as you have a heated garage but at 45 degrees I believe you may get a slight improvement based on what I have read. To increase winter range keep heat level as low as comfortable and use seat heat when driving.
