IPC Keeps Resetting While Driving
Orb7
IL
MachE Select
Hi
I often encounter an issue where my IPC keeps resetting itself repeatedly while driving.
Has anyone experienced something similar?
Thanks
Since you are in Israel, was this car produced for the Israel market, or did you import it? If you imported a US car, then the problem you are going to have is getting someone with Ford's FDRS to look at the systems and see what's going on.
Orb7
IL
MachE Select
This is an imported US car.
Actually I've already installed (almost) all updates in FDRS, hoping it would resolve the issue.
moethelawn
US
2023 Mach-E
Since you have FDRS or assuming you can still look with Forscan, are you getting any DTCs?
Orb7
IL
MachE Select
No, the only DTC I have is for the IPMA camera, which I assume is unrelated.
