Is seat memory working?
physib
N/A
I don't have my car yet, and I remember hearing about settings not saving to profiles. What about different seat memories? Can I save 3 different seat positions to 3 different fobs? I'm not planning on using PAAK.
DYohn
Valley of the Sun
2021 Mach E Premium Ex
We have 2 different setups programmed to two different fobs and door buttons. There are three buttons so I don't see why not. The MME will use the driver profile for the fob (or phone) that enters through the driver's side front door. For us it works fine.
Dnorwood98
D
WA
2025 Shadow Black AWD Ext Range/2021 Carbonized Gray AWD Ext Range (Previous)
Education/Healthcare
They do work, sometimes you have to press the memory on start up. I believe the latest update has fixed most of the profile loading issues if I remember correctly.
GoGoGadgetMachE
I'll add that if you have easy entry/exit enabled aka the "old man seat move", that seems to make the problem a little worse - sometimes my profile loads but the seat doesn't move back into position, and I have to hit the preset button.
I think it's tied to PaaK and a specific order of steps though (which I can give but won't here as irrelevant) so it wouldn't be applicable to the OP's question if I'm right on that.
DYohn
Valley of the Sun
My old man seat move seems to work properly most of the time (thank goodness) but yea, once in a while I find I need to hit the button when using PAAK. I also find that if I place the phone on the charging platform immediately and before I close the driver door, it works every time. So I suspect it's a blutooth connectivity issue.
