Issues connecting to Octopus intelligent
Nuts! Did Ford give a reason for blocking? Has your reading shed any light? I charged up over the weekend and my Octopus APP failed to control the charge or log the amount. The car seemed to decide for itself when it charged and then charged to 100% in an on and off way.
Sounds like y'all are encountering the issue we had on this side of the pond:
Sounds like you ran into this problem:
https://www.macheforum.com/site/thr...-use-can-disable-your-fordpass-account.13893/
Richarde
Richard
London
Mach e awd 2021
Hi folks
I was reading this post with interest as I have had issues with intelligent Octopus not charging at certain times….. what I found out yesterday was that for some reason the Mache modem (or TCU as it is also known) can turn off. I am still not sure why but I feel it is something to do with octopus trying to control the car??! Anyway when this happens it then means the car is not able to broadcast location and other stuff….. the upshot is octopus does not work properly.
I found a way to reset the modem without having to rest the whole system but it does involve taking out a couple of fuses…
here is the link for the video:
https://www.[Banned Site].com/threa...-stats-or-cant-remote-start-modem-reset.5605/
As I still can’t work out what trips the modem I am still at a loss as to what to do. I will revert to getting my zappi charger to charge at off peak times instead.
boltonmackem
Manchester
Mustang Mach E Select RWD
I am waiting for my MME Select arriving next week and we have had a Hypervolt 3 charger installed. Is anyone with this combination using Octopus Intelligent and how are you finding it? I understand that if you don't have an Ohme charger, they 'talk' to the car to control the 'smart' charging but in real terms, how does that work and is it straight forward?
StarLordRammi
Shropshire
would like to know this too.
I have the exact same setup (MME select and Hypervolt 3) but my charger is not installed yet.
Charging my car using 3 pin for now cause I'm currently on Octopus Tracker so it's not too expensive.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
It’s a hot topic and way too overcomplicated to go into in detail - let’s just say that Ford and Octopus are ironing out some niggles (putting it lightly!)
Until those issues are sorted it’s not going to end well if you try and use your FordPass account on the Octopus app - so best to not do that.
Use the settings in the car or on your charger app to set charge windows and maximum charge levels until it all gets sorted.
I’m sure some other forum members will gladly explain the issues at play ?
Richarde
Richard
London
Mach e awd 2021
An update….i received an email from Octopus asking for the email I use for my ford pass account….apparently they will pass this onto ford to ensure ford will allow octopus app to work with the car! So feels like a step in the right direction.
Maybe. They might also want it to plug into their backend software where the problem is being encountered.
I truly hope Ford and Octopus are working together over there to solve this. I am not aware of Ford resolving issues with Recurrent or the various energy providers on this side of the pond, despite this issue going on for over a year.
grovep
Manchester UK
MME extended range
I do believe it is resolved. My account was locked and I received the email from Octopus which I responded to and today the account has been unlocked and Octupus smart charging scheduled for tonight
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I genuinely hope so for all of you that have had problems with locked accounts etc.
Interestingly I never got the email from Octopus inviting me to supply my details - even though I had used my account to smart charge in the past.
I guess I’ll follow the advice in the Ford Community forum and ask Ford CRC to have my account added to the whitelist just in case I have a situation where my Ohme Pro is out of action.
If they get this sorted we’ll have nothing left to bitch about ?
grovep
Manchester UK
MME extended range
Car smart charged ok overnight and FP account still good. Here's hoping this is the pattern of things to come
cgp777
Surrey
AWD
I have a Hypervolt 2, with OI-go, tho had all the same issues with FP-lockout / octopus smart-charge and after several attempts, over the last year, to depend on Octupus, I gave up! The Hypervolt works really well with timed start/end, within the off peak and also when solar is producing enough, I can easily switch to manual-charge, within the Hypervolt app. Not sure if there’s any advantage to using octopus to control the charge my MME, unless any of you great MME/IO users out there know of any?
boltonmackem
Manchester
Have you still been able to get the 7.5p off peak electricity using standard scheduling on your charger? I got the impression you can only have that if you can get the integration working??
cgp777
Surrey
AWD
Hi boltonmackem,
I have the 7.5p off-peak tariff, which kicks in at 23:30 til 05:30 and my Hypervolt is scheduled to charge then. I didn’t need to involve Octopus, other than to enter car data, etc, on their website, in order to get the EV tariff, set up in 2022. I’ve not seen any advantage to using octopus app over my Hypervolt app.
Hope this helps.
boltonmackem
Manchester
Hi boltonmackem,
Hope this helps.
It does. Thankyou.
