Let's make EV's better for everyone- RATE YOUR CHARGING EXPERIENCE
I'm a big fan of telling companies when they've done good, and when they haven't. As any good manager will tell you, a company can only get better if it's customers are vocal.
The charging network has big issues. But you Tommy, and you Mary, and you Bufford - you call can help.
Rate your charging experience.
FordPass says it has added the ability to rate the charging session. Since I have used up my free hours, I can't verify that. Look for it, and rate.
EA has the ability to rate each location when you charge, giving them specific charger information, not just the station - add the number after the station number so they know the charger.
PlugShare - while you are charging, open PlugShare and checkin, and rate the charging session. This helps your fellow EVers skip Huber Heights, Ohio, Gainesville, FL, and other problematic locations.
Rate, rate, and rate some more!
Note - if you forgot to rate, you can go back and do it after the fact. EA lets you rate each session, and PlugShare you can add a comment anytime.
TruWrecks
Oregon
Mach-E Star White Premium AWD Ext (Ghost Stallion)
We are the early adopters. We are helping to lay the ground work for the next generation of EV drivers.
kgautam28
Eco boost 2016, 2021 Mach e FE, 2022 Mach E GT PE
Software
Electrify america, charge point and ev go always worked for me. Only once EA had issues, so 9/10 overall
AZBill
On the EA app, I always send them a message if I encounter an issue, even if I move to a different charger and get it running. They usually send me an email by the next day acknowledging the report and sometimes provide a follow up, such as we are sending out a tech to have a look.
EA also monitors Plugshare, so put up the issue there as well.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
I always be sure to rate on PlugShare. Just to help my fellow drivers. And I have gotten co tact back from EA before based on my rating.
