LOUD Charging Sound
awiginton
Alesia
Texas
Mach-e
Hi! Another charging question. I replaced by Ford charger, that came with the car) to a Grizzle-E - My garage is not insulated, so it can get over 100 degrees. When we went to leave this morning this is what it sounded like! Yikes! Should I be concerned? The Ford charger started sounding like this before I replaced it.
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
Sounds to me like it is the cooling fan working overtime. Have you got a departure time set in your setttings and is it set to cool?
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Did you walk around the front to see if the vents were open? (My guess is they were and those are the fans you're hearing).
If its over 100 in your garage then yeah I'd expect a racket.
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Car cools the onboard charger and the battery. If it is hot you're gonna have this happen. It cools the charger off with coolant running past the radiator and it cools the battery with the A/C compressor which requires air going past the condenser.
If you have a job 1 2021 with really old software this can happen too even if its not hot.
AZBill
Normal for Arizona hot summers, yes you should expect this in Texas too. It is the cars cooling fan running. My ChargePoint is set to provide 40A and it gets this loud in 100+ temps, even with all the latest software updates.
awiginton
Alesia
Texas
Mach-e
Yes, but this was about 10-15 minutes before the preconditioning is set.
awiginton
Alesia
Texas
Mach-e
Thank for the confirmation! I'm going to set the charging time to start around 10pm, maybe that will help a little!
awiginton
Alesia
Texas
Mach-e
Makes perfect sense! Thanks
MachTee
Andy
MME Premium Infinite Blue SR AWD
When I first bought the car in June last year, the fan would come on while charging even when it wasn't that hot. After an update applied at the dealer, most of the time I'd just hear coolant flowing with no fan. Sounds kind of like a washing machine sloshing water around when it starts flowing the coolant, but again no fan noise.
I'm not sure if that fan update was ever included in any of the OTA PowerUp updates. If it did it's not showing in the version history in Wikipedia. How long have you had your car? Perhaps you car doesn't have that update, or it could just be your 100 degree garage and does require the fan to come on.
TuxToaster
Salt Lake City, UT
2021 Infinite Blue MME Premium ER AWD
The preconditioning accomplishes two things - to precondition the temperature of the battery and the condition the cabin. As it takes longer to cool the battery, preconditioning starts well before your set departure time so it makes sense that it would be running the cooler 30 minutes prior, if not even a bit earlier than that.
911roger
Roger
Nixa Missouri
Mach e gt
RN
my gt has never made any noise like that. I’m sticking with the Ford charger and see no reason to change. I top off at 80% btw it’s been in the high 90’s all week
jlauro
Owosso, MI
The compressor for the AC is the part that is so loud. If it's only a little warm it only uses the fans, if it's really warm you get the AC too.... Faster charging rate ties into it (faster charge, more heat generated). In a closed garage in the summer (not sure the temp in there, but had to be over 100 in the garage) I have had it get loud with even a L1 charger as there is so much ambient heat it's the only option... If on the edge, lowering the charge rate can keep it from going into overdrive on the cooling...
Logal727
C
Definitely was a fan speed adjustment included in 2.7.1-2.7.4 when charging
