Mach E Accident, Assistance with current codes in car
Edgerton
2023 Ford mustang Mach E GT performance
Equipment service specialist
Hey All,
Sadly my mach E was invloved in an accident.
I am going to list the fault codes here if someone can help me figure out what ones might be disabeling my battery, that would be great, I know there are a lot of good people about the Mach E in this group. Car is getting towed to my buddys body shop and we are going to get the front bumper off it tomorrow. so we can really see whats going on behind it. but below are the codes that I was able to pull today.
OBD11
B11D5(00)
P1AOA(02)
P1A10(00)
U0298(00)(Archived)
ABS
U0594
BECM
B11D5(00)
U0298(00)( Archived)
IPMA
B1B42(08)
B148E
SOBDMC
P1A0A(02)
P1A10 (00)
VDM
U0442
tbrumleve
Tom
Oregon, USA
You can Google these codes to find what they mean. Search each code for their meaning. From searching “ford B11D5”:
Ford diagnostic trouble code B11D5 indicates a "Restraints Event - Vehicle Disabled" fault. It signifies that the Restraints Control Module (RCM) has detected a crash or severe impact event requiring airbag/pretensioner deployment, and as a result, the vehicle's high-voltage system or fuel system has been disabled.
Key Details About Code B11D5:Meaning: The restraints system has commanded deployment and the vehicle is disabled due to a collision event.
Context: Frequently seen in Ford/Lincoln hybrid and electric vehicles (HEV) related to the high-voltage battery safety shutdown.
Action Needed: Requires technical inspection of the Restraints Control Module and safety systems. It usually cannot be cleared until the system is serviced or the RCM is reset/replaced after a crash.
Drkvampire2001
Edgerton
Yes I know was more looking for what I can do to clear the to get the car to work again.
Sachmo133
Nashville, TN
2024 Mach E GT/Rally
Director of Streaming Services
Seems like that was in the reply. This sounds like the electric version of a pyro fuse. Most likely it will have to be reset by Ford. Did your airbags go off? If not are the seatbelts locked out?
Teslaeata
Nottingham, England, UK
RCMs rarely need replacing after crashes now.
They do their job, deploy SRS components and record collisions and are ready to go again.
Deployed/damaged SRS components require replacement as part of collision damage repair, DTCs (diagnostic trouble codes) cleared and you’re good to go👌
tbrumleve
Tom
Oregon, USA
Google the codes and they’ll give recommended actions. Your ask was for which error had disabled your battery. I googled the code that is responsible, and it lists the action needed. You’ll want to look up the rest of the codes as well.
