Mach-e FordPass activation failed for a few weeks
MasterJey
Aleksandr
Ford Mach-E
Any body could share piece of advice with an issue that FordPass can not activate vehicle?
Just before thanksgiving day my ford pass stopped to track charge level and control car from fordpass.
Got same issue several times before and it was resolved by fuse disconnect for a few hours but it is not the case now.
I have contacted FordPass support and we did all possible troubleshooting including door lock trick, removing vehicle from FordPass and master reset
p.S: In bezel menu TCU is always disconnected
I have a FordPass case escalated on Nov 22
Still no one called me.
What is best direction to proceed? Go to dealer service department? Call anyone ?
tnx on advance
Susan Taylor
Susan
Sand Lake NY
Mach-e CR1
Lawyer
tnx on advance
I am having the same or a similar problem. Have been disconnected from FordPass since 11/06. Dealer has ordered a new TCU but it’s back ordered and I am also worried that it won’t fix the problem. Anyone else have issues like this?
dbayub
Scott
America/Ohio
2023 Rapid Red Metallic Premium Standard Range AWD
Interesting. I just had a bad TCU and it took a week to come in. It didn't prevent FordPass from connecting, but most features did not work.
Susan Taylor
Susan
Sand Lake NY
Mach-e CR1
Lawyer
My car is again connected to FordPass. It was a bad TCU. Dealership didn’t check to see if it solved the problem; I spent an extra 2 hours there, after being told the car was all set, while a senior tech tried everything he could think of to get it reconnected. Eventually “provisioning” worked. My impression so far is that the dealerships are behind the curve on EV issues and repairs. Although my dealership is helpful and nice and trying hard.
MasterJey
Aleksandr
Ford Mach-E
Did dealer replaced TCU? How long it take ?
Steve4GT
Madison, WI
2021 Mustang Mach-E GT
IT Guy
Yes. Purchased a 2021 "Buy 'back. that said it had issues with APIM, well i cannot Activate Ford pass. Took it into Kayser Ford in Madison, where they said it needed a new TCU, it came in and then today they said it is failing to import my information. Tomorrow they will try to connect up again directly to the TCU...we will see...
jpiazza67
USA North Carolina
2021 Mach-E Premium x
Maybe try disconnecting to the blue oval network in the FordPass and then reconnecting and check the plug and charge button is turned on. This fixed a problem I had in October after a software update and they changed the blue oval from a subscription fee base to free access.
Susan Taylor
Susan
Sand Lake NY
Mach-e CR1
Lawyer
did they “provision” the new TCU? My dealer called to tell me the repair was complete and I could pick up the car but it still would not connect to FordPass. After a more experienced tech “provisioned” it, it connected right up. Took a while.
