Multi Error/ Warnings
jasonpel
Jason
Victoria
2022 Mach E Select
I've had the car for 12 days. Yesterday, out of nowhere it starts giving me Transmission Not in Park error when I'm slowing down for a light or an intersection; a Door Fault Service Required error; and it also returned a Hill Start Assist Failure warning.
These all came within an hour of each other. I'm hoping it's a 12V battery thing, so after a night of charging we'll see what happens.
Any insights out there?
Ford Mustang Mach-E Multi Error/ Warnings IMG_20220522_142203
Ford Mustang Mach-E Multi Error/ Warnings IMG_20220522_142157
newmme
Volt
I would take it to the dealer, especially only having it 11 days.
Ford Motor Company
Official Ford Account
Hey there! I can look into your Mach-E's warning concerns on my end if you’d like. Will you send us a message with your VIN and dealership info?
jasonpel
jasonpel
Jason
Victoria
2022 Mach E Select
Sure, here's the VIN and the QR code. Dealer is Suburban Motors 3377 Douglas St Victoria BC Canada
Ford Mustang Mach-E Multi Error/ Warnings 20220523_192002
Ford Mustang Mach-E Multi Error/ Warnings 20220523_192011
Looks like you have a few problems:
  • Your driver's door presenter is bad or the wiring is damaged (could be a bad door module too)
  • Your gear shift module may be bad and require replacement
  • One of the charging EVSEs you use has a bad pilot signal potentially causing charging issues
jasonpel
jasonpel
Jason
Victoria
2022 Mach E Select
Sure here's the VIN and the dealer is Suburban Motors, Victoria, BC, Canada
rcechinel
Atlanta
2022 Mach-E Premium ER AWD
Tech
I'm having all these errors since yesterday. Premium AWD ER 2022. @Ford Motor Company, can you check, please?
Fordpass said I should have it checked by a dealer. ?
