- Bill
- Feb 18, 2020
- Hawaii
- 2021 Premium Infinite Blue. ER AWD. 2020 Raptor, 2021 Ranger.
tl;dr It's the combination of humidity and temperatures.Do you use the FPP-89 filter? It could be happenstance but after I installed it I believe it restricts airflow enough that I've noticed my car does not defog as well as when I was using the original filter, like the algorithm just doesn't work quite as well now.
Climate control is a time based affair vs the distance drove and is significantly less, ever with head, than the car uses to move itself as was pointed out.
I do right now, but this goes back 4 years. The issue, for me, is that I live in Hawaii. It's not exactly dry here. Humidity is always an issue. To top that off, I live in upcountry, where not only is it humid, but it's also cool. By the end of this month, our daytime highs will be in the 60s, and the morning lows when I head to town can be anywhere from the high 40s to mid-50s tops. February daytime highs will be in the mid to upper 50s, with lows occasionally in the mid-to-upper 30s. However, the normal low for February at 6-7 am is in the low 40s.
I've gotten used to reaching down with my left hand and pushing the max
The winters are brutally mild here.
