User100723
So I’ve been comparing the different options out there, and I’m stuck between two options. Def don’t want to go with any of the numerous cheap uncertified Amazon adapters, no matter how many positive reviews they might have. Lectron has been ruled out as well, especially after watching one highly-rated product after another suddenly experience major, sometimes even catastrophic/life-threatening issues.
The two I’m trying to decide between are:
1. The OG TeslaTap Mini Lightning adapter (http://www.umc-j1772.com/index.php?route=product/product&path=17&product_id=174)
and
2. The newer & cheaper A2Z Stellar Tesla To J1772 adapter (https://a2zevshop.com/collections/charging-adapters/products/a2z-stellar-plug)
In comparing the two, I find that both are rated as 80a adapters, but only the TeslaTap is described as being rated specifically for continuous 80a load. Does anyone know if the A2Z adapter is also a continuous load adapter, or if the 80a rating is only for that current spike at the beginning of the charge?
Also, anyone with experience using both adapters? How’s the build quality/durability between the two adapters? Ease, speed and reliability of connecting and sustaining a charge?
Finally, I notice that the A2Z adapter has a built-in theft-deterrent lock and key mechanism. Looks much more convenient than the dual pad-lock loops that the TeslaTap offers. Two questions about the A2Z:
1. Is this a double-ended lock, or is it single -ended? In other words, can it actually lock both the cable and the car together (so as to prevent the unauthorized disconnection of either the cable or the adapter from the car), or does it only lock the adapter to the car (which would allow some rando to interrupt a charging session but not walk away with the adapter)?
2. Anyone experience issues with dirt, grime, snow, rust or any other elemental buildup/corrosion due to the upward-facing orientation of the keyhole on the A2Z adapter? As convenient as it the built in lock may be, the last thing I want is some grime or ice to prevent the key from fitting into the slot and releasing the adapter. Would this ever be a concern for overnight charges with mixed weather, such as wind, rain, dust or snow?
Both adapters look really good, but the price difference is significant, so would like some insight from the community. Thanks!
and
