Pairing a Comma 4 with a dash camera (the Thinkware U3000)
CarDreams
Charlotte, NC
Mach-E ER Premium 2022
I have a Thinkware U300. I want to get a Comma 4, but I am concerned about connecting both to the Mach-E's OBD-II port. I dont know if this is possible or if it would cause a conflict, since the Comma system requires a clear, uninterrupted stream of high-speed CAN bus networks to handle lane centering and radar cruise and the Thinkware U3000's advanced radar and power management systems occasionally monitor the vehicle's data lines (CANBUS) to determine ignition state or vehicle status.
Would a splitter work (like an OBD-II Y-cable where one female tail has all 16 pins wired (for the Comma device), and the second female tail has only pins 4/5 (Ground) and pin 16 (12V Constant Power) connected?
alexw
Alex
Los Angeles
2024 Mach-E Rally
Electrical engineer
Should work fine with a splitter. The Comma doesn’t actually need the OBDII connection in the first place - it’s just for providing power after the car is off so the comma can, for instance, upload routes to the cloud service while you’re parked in your driveway with access to your home WiFi.
And since the harness tap location for the Mach E is in the trunk instead of behind the mirror, most of us just don’t run the OBDII connection at all. I’m not even sure under what circumstances the canbus connection on comma power is used.
CarDreams
CarDreams
Charlotte, NC
Ok thanks for that! I'm really interested in comma and I plan on going "all out" on my second mach e ☺
