Profile Strangeness
Navy Bird
Rochester NY
2022 Mach-E Select
Retired baby!
My guest profile has the lane keeping system turned on, and it works just fine. I then created a new profile for me, with the exact same settings as far as I can tell, and the lane keeping system is not working. No graphic on the instrument panel, no vibrating wheel when I drift over the line. I cannot for the life of me figure out what is different between these two profiles. I went through each setting and compared between the two profiles and they look to be identical. I have SYNC 4.1.3. Has anyone seen a similar situation or have any advice? Is there some setting that I'm missing?
Confused in NY,
A-A-Ron
Aaron
DFW, TX
'21 MME Premium 4X
Confused in NY,
Have you turned it on via the steering wheel button?
Navy Bird
Rochester NY
2022 Mach-E Select
Retired baby!
I never thought to check that. I made my new profile by saving the guest profile under a different name - I never thought that would turn off the steering wheel button. I will check first thing tomorrow. Thanks!
Cheers,
Navy Bird
Rochester NY
2022 Mach-E Select
Retired baby!
I couldn't wait until tomorrow so I just went out and checked. Sure enough you were right. This tells me that when I created the new profile, either I hit that button somehow without realizing it, or the software defaulted back to the button being off. It must be the former, as the latter sounds pretty dumb. Actually, the former sounds pretty dumb, too. But I'm old...
Cheers,
