astrorob
- rob
- Aug 26, 2022
- bay area
- 24GT, plug-in prius, 99 MBZ C43
in a half asleep haze this morning, the thought occurred to me that if you could install a switch that would cut the 12V power from the frunk actuator, then you could avoid the problem where the override system does not work due to low battery voltage, as in the case the infant stuck in the car the other day, or in the situation with the update where people were routing string to the front door handles inside the car.
in theory you could route this switch down to the front bumper access panel so that you could throw the switch before energizing the emergency open circuit. i suppose if you wanted to get fancy you could use the presence of 12V on that override to open the switch, but i'm not sure if the latch assembly would be happy with a simultaneous loss of car 12V and application of backup 12V.
has anyone looked into this? is it even remotely possible?
