Rear Heating
terry_mach_e
MI
2021 Mustang Mach-E4X | Rapid Red
When the Mach-E is heating the cabin (E-Heat is on, in Auto, and the temp. setting is significantly higher than current cabin and exterior temp.), no air flow is evident from the rear passengers' air vent. Is this normal?
When the aircon is set to cool, there is a clear breeze felt from that vent.
timbop
Do you have it set on auto? The rear vents only output when the center vents are active; for heat in auto it probably just uses the floor vents and/or the defroster; you'll have to manually enable the middle vents
terry_mach_e
MI
Yes. It's in Auto. Next time, I'll check if I can manually trigger the rear vent. Thanks!
With auto, the rear passengers often freeze for a minute or two until the floor vents sufficiently heat the cabin. ?‍♀
Hence Remote Start. Or pre conditioning.
