Rear turn signal, litigate module flickering, fix
rbertonieresr
Rob
Madisonville, LA USA
2023 Ford Mustang Mach-E
My passenger side tail light ( the litigate module) was flickering and finally stopped working at all. The lights in the fender module still worked, so I continued to have working break lights. That assembly is close to $800 to change.
I popped out the trim, unplugged the assembly at both locations, then plugged it back in and it started working again.
I assume it worked itself loose from opening and closing so much.
Anyway, something you can check if it happens to you.
