Changing the Turn Signal
Bryan G
Bryan
Sacramento
2024 Mach E Premium X
Owner
I have a 2024 Mach E Premium extended battery RWD. Currently, my blinkers only blink twice when you tap it. Does anyone know how to change it to 5-7 beeps when tapped
Teslaeata
Nottingham, England, UK
Yes, in setting on centre screen, I seem to remember it’s a time in seconds you can alter.
Pretty sure there's a parameter in FORscan that will change the number of blinks for a touch of the lever. Not sure which one it is. Take a look at the FORscan spreadsheet thread. ??
markboris
Sonora, CA
Yes, it can be changed in FORScan.
Edit: I have only changed the amount of blinks after tapping the turn signal lever in F-150 Lightnings so I assumed you could also do it in the Mach-E but I can't see where this is possible. So as far as I can tell, it is not possible to change the amount of blinks.
Karlos
Karl
DFW
2024 Mach-e Premium ER, 2022 Lightning LER, 2023 Lightning LER
Retired CPA
Not finding any mention of turn signal in the spreadsheet - anyone know the codes for 5 & 6 blinks ?
markboris
Sonora, CA
After further looking, I don't think we can change the amount of blinks. I edited my previous post mentioning that I have changed this setting in F-150 Lightnings so assumed we could do it in the Mach-E but I cannot see where this is possible.
McSquashy
Josh
Massachusetts
Out of all the settings I was hoping to be able to adjust with FORScan, changing the number of tap blinks was definitely high on my list.
I hope someone is able to figure it eventually.
markboris
Sonora, CA
Not sure why we can configure this and many more modules in the Lightning but the Mach-E is much more limited.
Snakebitten
Coastal Texas
2023.5 Mach-E
Yeah, like the VDM in the F150 vs the Mach-E.
Although I must admit that Magnaride and CCD are different methods for damping adjustment.
Still, the dynamics that are being measured with height sensors, etc, should overlap fundamentally?
