Set for 85% charged to 100!!!
Krimpy
2021 Mach-e EXT AWD Space White, 2016 Mazda CX-5
Realtor
I adjusted the charging setting last night to 85% prepping for a longer road trip today. Got in and it’s at 100%. Wtf?!? Shows to charge to 85% in the car. And if someone says use your app that is not an excuse that should be an override. No reason it does that and it has now done that to me twice. What gives @Ford Motor Company
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Go into Charge Settings in FordPass, just to confirm that "Use preferred charge settings" is Selected, Not "Charge when plugged in". I have had it default to a different setting before.
Dnorwood98
D
WA
2025 Shadow Black AWD Ext Range/2021 Carbonized Gray AWD Ext Range (Previous)
Education/Healthcare
Also, sometimes there is a bug in charge location (car thinks it isn't where it actually is) that can make preferred settings not work as well.
Krimpy
Realtor
Do some searching, like 50 threads on this same known issue.
I forgot why I hate posting on here. Thanks for the reminder. Why even say anything. You’re the dude that won’t shut the blank up in the bar and everyone wants to punch in the face but doesn’t because the first thing you do after your mom gets done making you feel better is lawyer up.
thank you! Much appreciated it had defaulted as you said.
Krimpy
Realtor
Yeah. I’ve had to reset the charger before for issues. Thanks again.
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Love you too just do a simple freaking search lmao. It's so easy. I almost posted some links after searching minor words to help you but decided you could do it yourself and save yourself some time (Found 3 threads with the answer to your question in 30 seconds or less).
I also didn't make a shitty analogy calling you someone that people want to punch in the face but you know....
txaggies07
Aaron
Texas
2021 MachE FE Rapid Red
Mine always charges to 100% after it does an update. Then the next time it remembers what it is supposed to do and works correctly.
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
That was pretty much uncalled for AND he was right.
I’m not real happy with you posting on here either.
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
My dude...I think you overreacted a bit here. woosah.
