nivlem
- Walter
- Aug 8, 2020
- Tx
- '66 Mustang;'79 Mustang;2015 Genesis;2021 Mach E
- Retired
On at several occasions I've tried to turn on my SiriusXM Radio, but it didn't work. In some cases it would go to a channel that I had not selected, or it would just stick on a channel. Either way it would not allow channels to be changed. On other occasions the screen would display "SiriusXM Loading...", but never load. The third type of occurrence is the the screen would display "Hardware Problem", and not work. In each case, except the "Hardware Problem" I called SiriusXM technical support. They tried re-hits and other measures but could not resolve the issue. They recommended that I contact the Dealer. The problem always seems to resolved itself within a day or so and functioned normally (including the"Hardware Problem" ). This is a continuing problem and it certainly does not seem like it is the way the radio should work. I am scheduling a service appointment, but I am wondering if anyone has had a similar experience. If so, how was it resolved. Thanks
