Sound Proofing a Mach E from Road Noise
Michigan, MI
Mach E GT 2021 mustang
Has anyone successfully sound proofed their Mach E from road noise. Thoughts on this so far? It's sticky padded materials and thought about sealing the plastic and edge.
Ford Mustang Mach-E Sound Proofing a Mach E from Road Noise 1000006773
User100723
United States
GT
Just curious, have you done any tests to determine where exactly the noise is coming from before trying these mods? There’s an official TSB (or alternatively, diy hacks) for wind noise if that’s a concern.
Also, what kind of road noise are you trying to eliminate? The lighter tire/wind noise you hear on smooth highways, or the more rumble-y kind that’s much more apparent over cracks and potholes on bridges and local roads?
RogueLegend
Shadi
Seattle, WA
Mustang Mach E Premium AWD
I just traded in my 2019 I-Pace for a 2023 MME. Funny enough, when we test drove it, we compared with decibel meter, and the MME was 1-2 DB quieter at highway speeds. I think I got the clue to check from Bjorn Nyland's test results.
Depends on the noise.
Two ways to reduce noise-
1. reduce vibrations by adding weight. That’s the sound deadening material.
2. reduce the cause of the noise. This could be filling gaps that cause wind or changing tires to reduce road noise, etc
I would first determine which noises you are trying to reduce and start there.
@markboris found pretty much all of the noise ingress points in his car and insulated those places. Search for his posts about audio systems and subwoofers. ??
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I can tell you that little tip about the screen rubber, the rubber that goes around the screen on your window at home near the mirrors, that totally has quieted down the wind around my windows.
Ford Mustang Mach-E Sound Proofing a Mach E from Road Noise IMG_7582
Hammered
SE US
2022 PB F150, MME GTPE
That's doing a whole lot of nothing. Need to focus on the doors and areas around the wheel wells as well as in the trunk area behind the plastics.
FordFamily
2022 Mach-e Premium ER 4X
I’d like to give it a try. What did you change, and where?
FordFamily
I just added this little 10 1/2 inch piece of screen retainer rubber on each
Thx Jerry. So, just go to a hardware store and ask for “screen retainer” rubber strip? Squeeze it in m the groove?
Moxiemoney
Brent
Portland, OR
'23 Premium AWD ER
That's definitely the easier way to go probably. I used painters tape and put black silicone caulking in there and then removed the tape on either side of the groove. You can't tell. It def helped with the wind noise, but overall, the wind noise from the front window areas are still bad compared to my previous cars.
kindofblue
Reid
Arroyo Grande CA
Grabber Blue Mach e Premium 11/5/22, '25 Lexus 45h+ PHEV
It's called spline material. Our local Ace Hardware sells it by the foot. Get the thinnest they've got as it comes in different diameters.
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I suppose any home improvement I ordered mine on Amazon and it came with like two little tools and 32 feet of this stuff for like eight bucks.
Ford Mustang Mach-E Sound Proofing a Mach E from Road Noise IMG_7693
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
The little roller tool I would not use that to put it in. I just use my fingers that way you don’t scratch any of the plastic and the other little pic. That’s just if you want to take it back out you can just put it in the end and pull it out real simple just don’t push it too far cause it kind of disappears.
FordFamily
Much appreciated. Does anybody have experience with putting tape along the top edge of the windshield? That’s a significant groove; I recall that earlier Teslas had quite a bit of turbulent noise at that location. (A friend with a model 3 reported my MME is much quieter on the road.)
