Spare Tire Options?
Flint302
Northern NJ
2021 Mach E Premium AWD, 2016 Audi A3
Retired government
I bought the Modern Spare and just placed it in the cargo area. It takes up some space, but I just pull it out if I need the room. I bought the jack and tools that go with it. I've never have had to use it yet--but if I need it, I won't be sitting around a few hours waiting for help. It cost a few dollars and it's worth it for the lack of stress of getting stuck somewhere for who knows how long.
64-1/2baby
kevin
Lavernia
23 Select 2wd
retired pipefitter
Your search may be too narrow. Search for "175/80r19" on eBay and a ton of spares will come up. The Mach-E has a 5x108 bolt pattern, so any car with the same pattern will work. The Fpace, Ipace, range rover velar, and more have that pattern, so any of those spares will work. I saw a few for around $150 shipped just now.
Car-part has even more if you search for a late model F-Pace, look for wheel, and pick the 19x4.5". They also have a 20in aluminum spare if you want to be extra fancy
Thanks for the information! You may have just saved me a roadside emergency sometime in the future!!
RolyMach
Paul
England
2023 Mach E Select Long Range - Space White
I bought a full size tyre and wheel from eBay for £170 the tread was 5mm and it goes into the trunk when we go away, yes it takes up space but with only two of us it’s no problem. The spare wheel came into its own recently when I had a puncture so I changed the wheel and took the flat tyre for repair.
Ravens2025
Maryland, United States
Mustang Mach-e premium
So will a 2018-2023 LAND ROVER VELAR 19X5.5 EMERGENCY SPARE TIRE WHEEL fit a 2025 mach-e premium. Chatgpt has conflicting data and says no.
Ravens2025
So for my mach-e 2025 premium, I purchased a 2018-2023 Velar 19x5.5 that is 175/80 R19 off ebay for $116(with ship) and it looks taller than the OEM tire on the car or that is not an issue. Should I have purchased the R18?
