Speed limited to 80 mph
Sinclair63
Scott
Blythe Island, Ga
2023 Mach E GT
Engineering Manager
I was out of town for 7 days and my 2023 GTPE was left in the garage plugged into a level 2 changer to keep it at 80% charge level. Once I got in to run an errand, the dash flashed up a notice the car is limited to 80 mph. Anyone else seen this notice? Any reason it appears or ways to delete this restriction?
Sounds like somehow you setup a MyKey. Use your other key to remove MyKey.
Deleted member 19354
Guest
Just got back from Montana and the 90 freeway was 80mph
Sinclair63
Sinclair63
Scott
Blythe Island, Ga
2023 Mach E GT
Engineering Manager
Okay, I will look into how to do that. Thanks!
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
If you have a suspension fault, that could cause this. If you have an issue with the motor lubrication, that could cause this, and MyKey as mentioned above. Take pictures of any and all error messages on the dash you ever experience.
Hartland
Peter
Hampshire UK
2024 Mach-e AWD Extended
Civil Servant (retired)
When you start do you get a yellow warning flash up saying MyKey. If you do then as default it sets max speed to 80mph. To delete you need to use your other key place in the bottom pocket in the center console & rest
Ford Mustang Mach-E Speed limited to 80 mph blink
