Stopped Taking Charge 2500 Miles In
rolesky22
Ryan
Los Angeles, CA
2022 Premium ER
Accountant
I get free level 2 charging at my office so that's where I do 95% of my charging. It charged Monday for a little over four hours and then all of a sudden stopped. There was no fault message. I hook it up again on Tuesday and it looked fine for 90 seconds, then stopped again. I tried 3 different chargers including a fast charger on my way home and no luck at any. The charging ring goes from blue to white, never the orange. Any one else experience this? I had to take it to the dealer and they don't seem to know what's going on after having it for 24 hours.
devmach-e
SF Bay Area
Unix Sysadmin
What percentage did the charging stop at?
Send me your VIN, overheating is my guess but I can check.
EDIT: Cause is the J1772 not fully latching.
Thank you for checking!
3FMTK3R73NMA31381
You have a P0D56:24 code, so the J1772 might not be clicking in all the way. Check for debris. Verify the charge port locking pin is fully retracted and not damaged per this:
https://www.macheforum.com/site/thr...icator-in-the-ipc-and-or-multiple-dtcs.21850/
And then read my TSB about P0D56 codes:
https://www.macheforum.com/site/thr...ssage-p0d56-code-and-12v-battery-drain.23525/
FYI the red flashing charge fault won't occur until 30 seconds after the connection, so you probably didn't see it.
Looking further back there was a P0D80 code on Nov 3rd, this means the EVSE did not send AC power when the car requested it. This was likely caused by a faulty EVSE.
rolesky22
Ryan
Los Angeles, CA
2022 Premium ER
Accountant
Very helpful. Thank you!
