Tinny speaker... intermittent
markleigh
London
www.mark-leigh.com
MachE RWD ER / Abarth 124 Spider / Morris Minor
Most of the time the sound system is fine... but ocassionally the speakers sounds like old mono ones... very tinny. Even the warning 'beeps' sound off. Next time it'll be back to normal... Anyone experience anything similar? Thanks
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
Happens when 12v SoC is too low.
markleigh
markleigh
London
www.mark-leigh.com
Thanks. What would cause it to drop? Prolonged use of the A/C?
Logal727
C
Never run the car in accessory mode only, always make sure it’s on so the 12v keeps topped up
Gullwingdmc
Chip
Boston, MA
That was the case in my old 2014 Fusion, but I don’t believe it is in the Mach E. Last time I got the low quality backup beeps I put a OBD2 reader on and my 12v battery was at 14v.
Scooby24
Olathe, KS
Healthcare IT
Several of us have experienced the same thing. The 12v is reading low and some of the sounds end up going through a speaker on the IPC. At the same time the 12v is being charged so you drive it around a bit and even though the sounds are strange, by the time you look the 12v may be back up to charge but the car needs to have a power cycle to fix itself.
juggler
2021 Mach E Select
I’ve noticed when I’m playing music through CarPlay on my iPhone through Pandora and then switch to the Amazon shopping app that sometimes the sound will become tinny… as soon as I close the Amazon app the sound returns to normal… not sure why this happens.
Gullwingdmc
Chip
Boston, MA
I checked it right after I turned the car on and heard the sounds. I was concerned because I knew of the low 12v tell from my previous Ford. I’m not saying that the low 12v battery can’t cause this, just that it’s not the only cause.
Scooby24
Olathe, KS
Healthcare IT
Were you just looking at voltage or at SoC for the 12v? I'm assuming if it's the charging cycle, even if the 12v is low it will read high because the voltage is up to charge the battery. So if you had the car on and checked the voltage, it's high because it's charging the 12v because the SoC was low.
Gullwingdmc
Chip
Boston, MA
I was looking to check the voltage, but I remember the SOC was in the 90s. I don’t remember the exact number.
Noctivigan
Charleston, SC
Current GTPE Grabber Blue,Previous FE Grabber Blue
Scooby24
Olathe, KS
Healthcare IT
Noctivigan
Charleston, SC
Ok any recommendations on car scanner and OBD2 readers that you'd recommend? thanks again
Scooby24
Olathe, KS
Healthcare IT
Car scanner is the app, and works with many different OBD2 readers. I use the vlinker FD adapter (model depends on which android/iphone you have)
markleigh
markleigh
London
www.mark-leigh.com
Thanks all so far. I've only noticed it lately - which corresponded with running a/c all the time (not in accessory mode though) which is why I wondered if there was a correlation... (Prob not)
