Trunk lid release on the SYNC screen
Steltzie
Irv
Wells ME
2021 Mustang Mach-e Premium AWD
Ever since the latest SYNC screen layout change I can't find the Truck or Frunk release button that I believe used to be under Driver Assistant. Did they remove it??
They moved it. Asked often.
Click on middle button on the top left of the screen. You will then see the buttons on the top right.
DTRINGO
DAVID
Pembroke Pines
2023 mustang Mach-e
THIS NEEDS TO BE FIXED IT'S A REAL PAIN WITH NO OTHER WAY TO OPEN TRUNK IT'S EASIER TO OPEN FRONK
You can’t fix not broken.
The trunk release is on the opening screen of the settings menu. Upper right corner of the drive mode picture. Or you can exit the car and press the button on the liftgate.
ArthurDOB
Arthur
High School Teacher
Not even if you demand it all in caps?
If that's him in his profile picture, he probably accidentally hit the caps lock key and has no idea what all-caps signifies. ?
Well, one could replace the Max Defrost button with a liftgate button from an Exploder… But that’s an addition,, not a fix. ??
Ford Mustang Mach-E Trunk lid release on the SYNC screen IMG_3299
