Trunk Lid Won't Close - It has a Sensor??
TheCount2
Marc
NJ
'21 Select with BlueCruise Job 1 21P22 SW Update
Actuary
I parked in my office building garage yessterday foir the first time, opened the trunk to get out my briefcase, pushed the button to close the trunk, and it wouldn't, closing a few inches and giving me the whomp-whomp signal. I finally looked up and found that there was about an inch of clearance between the right edge of the lid and a steel beam in the roof of the garage. I moved the car a few inches forward and was able to close the trunk without a problem. I haven't found this feature/sensor documented, nor found anyone else mentioning the problem.
JmanMachE
Jerry
Needham, MA
2021 Mach E Premium AWD ext. range
I had intermittent trunk closing issue with the 3 beep not-going-to-close signal. I did two things to apparently fix it. i changed the max open height to lower than the max. I also cleaned the area around the trunk closing mechanism and latch. In my case there was nothing over it, that may be a red herring and you may experience this again.
timbop
So pushing the door down with your hand to close it wasn't an option?
AllenXS
Allen
Richmond, BC, Canada
Premium Blue ER AWD
I think closing it with your hand upsets it.
It gets a little pissed for a few moments but gets over it.
timbop
My Mach E doesn't have a power trunk, but other cars I've owned did and it was not a problem to manually close them even after pressing the "close" button.
AllenXS
Allen
Premium Blue ER AWD
Sometimes these things go in the wrong direction. So far with interfering and stopping it a few times it always seems to then go in the right direction for what I want.
TheCount2
Marc
NJ
Actuary
I ws reluctant to push it down past the point at which it resistance increased significantly, as if maybe something was blocking the arms or hinges.
