Typical Charing Rate
Jskish3
Ford Mach-e
I have a 2021 Premium AWD JOB 1 EA. (95KW battery) Predominantly been using EA for fast charging on road trips. I have noticed irregardless if I am at EA 350Kw chargers or 150Kw, the charge at best case seens to be like 110kw, and quickly drops down to the 80-90KW range.
Curious. Is it
my pony requesting a lower rate or the EA reducing output? Any way to tell? What should I be expecting on a good day?
Anders31
Anders
France
Mach-E SR RWD 2023, Star White
on the ER, the peak of 150-162kw is only during 2-3 minutes, then drops to 110-80kw
on the SR, the peak of 115-125kw same, then drops to 95-90kw
what is important is the specs:
ER is rated for 45min 20-80% and it stays within specs at 80kwh
SR is rated for 38mn 20-80% and same, does it within specs at 75-80kwh
The real matter is the curve, not the peak charging rate
now SR LFP will be able to charge faster because LFP can handle more C than NCM so LFP may be able to charge 20-80% in 25min
4sallypat
Pat
www.kudo-ume-farms.com
Network Tech
@Anders31 is correct.
Would not worry about peak rate but overall charge.
Could be a number of reasons but peak charge rate is not consistent as many factors come into play - temperatures, start of SOC, rate of charge tower output, etc..
I never worry - sometimes it's faster than I expected, other times slower than I expect...
