Unit of Measure for Navigation
dalola
SE Ohio
sunsetridgecabinhockinghills.com
24 Mach-E P4X, 24 Bronco Big Bend Sas, 22 Maverick Lariat FX4 4K, & Hot Rods
Retired 🇺🇸
Hello all! New member here.... Just picked up a new '24 Premium AWD, and learning as much as I can... One thing that has me stumped.... my navigation screen is in metric, and I cannot figure out how to get it to standard. In the main vehicle settings, it's set to standard, so I'm guessing it's a navigation setting, but I'll be damned if I can find it. Any help?
Did you tap on the settings icon in the nav? I think it’s a gear icon.
dalola
dalola
SE Ohio
Retired 🇺🇸
I did (several times..), didn't see anything regarding unit of measure....
ronsonk
Ken
Canada
2024 Mach E Premium
I was seeing the same thing wrt tire pressures - in Canada I like metric for distance, but PSI for tire pressure. Even if I set the units in-car to what I wanted, tire pressure was still in KPA.
I found I had to change the units in the FordPass app as well - then everything worked:
Account -- Account Information -- Units of Measure
dalola
dalola
SE Ohio
Retired 🇺🇸
Thanks for the info! I checked my app, everything was correct. So, still looking for the needle.... it shouldn't be this difficult! :eek:
Well, you are a resident of O_io, so things are often harder for you guys...
Ford app has nothing to do with the Navigation. In the vehicle, change the units to Metric (settings, general, km). Then, go back to Navigation. Then, go back to units and change it to miles, now go look.
dalola
dalola
SE Ohio
Retired 🇺🇸
lol...smooth sailing in xichigan? I've driven up there....:wink:
Wifie is out driving now, I will follow your procedure when she gets back. I won't ask how that makes any sense, as long as it works....
Your failure is assuming that it has to make sense...
If you Google, you'll see this isn't totally uncommon for a Ford to have this issue. And, this is the prescribed fix. Perhaps the person who designed it went to a school down south?
dalola
dalola
SE Ohio
Retired 🇺🇸
Doesn't have to, but it's always a nice surprise. And for every one person who designs something, there are 10 who approve it. They are probably the southerners.... :p
I will never live down helping someone from O_io...
