2021-MMEx-RT1
- Aug 18, 2021
- CA
- 2021 MMEx CA Route 1
- Yes
Ignore that, just a glitch in the matrix...Look like same dark gray as mine.
So now I have to get a mountain bike ;=)Mine updated this morning after pushing the Update Now button and I did not lock the doors, that should not be required. It simply told me to turn the car off before it would start the update. Took a ride on my mountain bike and when I returned it had updated, less than an hour later.
probably a mirage. Bright Virginia sun !Ignore that, just a glitch in the matrix...
Looks like manual update failed. looks like same list of updates, althought, as someone noted, the new update will let you check more than one day. It now lets me check them all. I did that and scheduled an update for 14:00. Will see !You may not be doing anything wrong per se.....it might be that your car isn't ready to receive an update. There might be active DTCs or low battery charge or any number of other things that might not allow the OTA to execute.
https://www.macheforum.com/site/threads/22s41-22s29-recall-ota-software-are-out.19436/post-481142
Maybe you can try setting a schedule for overnight? That seems to work better IMO...
These cars get extra glitchy after some of these updates. Equally strange, those glitches seem to taper off or vanish completely after a short while. I can't even count how many features were affected by various updates....dozens and dozens. At first I got all worked up about it because I assumed I was stuck with a broken feature forever or at least until another OTA came along to fix what was just broke.Apparently the Scheduled Update worked (although it set off the security alarm four times while the screen said Updating). After the Updating screen went blank, I got in and it showed a little download icon with a checkmark. The only other strange thing (so far) is that I set the update for 2PM and after the update the scheduled every day update time went back to 2AM.
Hopefully some of this made the touch screen more responsive. Previously the only thing that seemed to be istantaneous was turning on the FM radio.
In your car's settings if you have the "walk away lock" toggle switch active; it will text you through Ford Pass App. I think it may be the one thing on my MME that has been rock solid since day one of ownership. Hope that helps.I don't mean to highjack the thread, but how do you get the text that the doors locked?
