What’s the NECESSARY service required for Mach e ?
frstsgt
Polk County, Florida
EMU - Premium Rapid Red, RWD, ER and 2013 VW EOS
The owners manual is an option in the center screen. 10,000 mile service intervals of tire rotations and coolant level checks. That's about it IIRC... You can download a PDF of the manual which is a little easier to navigate.
Brake pad wear and brake fluid changes are about the only other things to keep an eye on maintenance wise that I can think of.
Brake flush is in the manual but not in the Ford Pass app. I took my ‘21 in for servicing (30K) and the dealer said they don’t do the brake flush any more. Go figure, but saves money.
RmP
RmP
Mach e
Good to know. I’m just trying to educate myself knowing dealers won’t be able to make much money on maintenance with EVs like they can with ICEs
Tire rotations are it. Otherwise, mostly visual inspections until it’s time to flush coolant, brakes, and change transaxle oil. If you have all-season tires, recommended is 10K miles. If you have the Summer UHP tires, rotate more often. If you drive hard, rotate more often. I rotated my Summer UHPs every 3K miles. I do my All-Season rotations every 5-6K. All in my driveway. ??
There are enough relatively new systems in the car not really related to the actual driving of the car itself (sensors, safety systems, entertainment stuff) that can go awry that dealers will still be making something on service. Those things don’t break down all that often but there is a lot of opportunity. ?‍♂?
