What do these updates do?
MrLoganRoss
Seattle
Mach E
I have a 2023.5 GTPE. Thanks to @21st Century Pony , I got a list of updates from FDRS. The dealer took the car and completed 1 major update - APIM.
However, they refused to update the others, and provided every big-corp bureaucratic excuse (I.e., the updates might break the car; they will come OTA eventually; we have to perform HW diagnostics based on symptoms first). I think the service manger came over and ground everything to a halt.
does anyone have detail on what these updates actually do? Has anyone had a dealer experience where they actually cooperate?
RGTM
RFA
IPC
thanks in advance!
RGTM - Trunk opening problems
RFA - Phone as a key problems
IPC - New software in preparation for BC update, also fixes some minor bugs.
MrLoganRoss
Seattle
Mach E
Thanks. Seems like IPC is the one that would be great to have, but I guess it will come with BC 1.4.
Sure, it would be great to have but it won't do you any good until you get the others. It will be coming to your car soon as a PowerUp.
You have a 2023.5. It's mostly up to date from the factory.
Runningslow
Anthony
Madison, WI
2023 Job 2 MME Premium 4X Carbonized Grey
I also have a 23.5. I have received a number of updates in this series.
6.1.0
6.2.0
6.2.0 re-release
6.6.0 (maybe it was 6.8.0?)
6.13.0
23-PU1103-NAT-VCE
6.1.0
6.2.0
6.2.0 re-release
6.13.0
23-PU1103-NAT-VCE
Correct. Even the 2023.5 Mach Es are getting the 6.x and higher PowerUps as they leave the factory with BC 1.3 and will need the updates to move to the latest BlueCruise. Getting one or two module updates via FDRS won't help that process along. The IPC update in 6.8.0 changes everyone else's IPC to the configuration already found in 2023.5s from the factory.
eddieparker
Eddie
Greater Seattle
2023 Mach E GT Performance
Pardon my ignorance - fellow 2023 GTPE owner here. How do I tell if I have a ".5" or not?
Tempted to find out what list of updates I'm missing but maybe ignorance is bliss... :)
Was your car made in the 2nd half?
eddieparker
Eddie
Greater Seattle
Sorry, I assumed that's what it meant. I guess I just don't know how I find out? I bought it off a lot but I don't know how long it sat there. Probability probably says it's first half...
Are there differences of note between first and second half of the 2023's?
Read your door sticker.
MrLoganRoss
Seattle
Mach E
your window sticker shows the build month.
Space_Pony
Indiana
2023 Premium Mach-E awdX
Second half only has 90 day trial of BC. When does your BC expire?
