dbsb3233
- TimCO
- Dec 30, 2019
- Colorado, USA
- 2021 Mustang Mach-E FE, 2025 Porche Macan Electric
- Retired
No error messages, at least yet anyway. I really haven't spent much time checking it all out yet since we got back though.No errors when it boots just does not go into gear? Only time it would not go in gear for me is when the 12V was weak and it would spit lots of error messages at me as it failed to boot clean due to lack of juice. Charge it and all was good here. Can you read codes or maybe someone here can help you out.
Recommend drilling ports through the cover to hook up a 12V charger. It is not as frustrating when you need to put a charger on it. I have ports and the 12V charger in the frunk for those long trips after it stranded me once.
4 years ago I thought about drilling holes in the cover but then I had the HVBJB issue 1000 miles from home in 2022. Had to pull the panels multiple times (thinking it was the LVB at the time). Once you pull those panels a few times, the clips aren't nearly as tight and it rather easily pops off, so I didn't bother with holes. I don't even need a screwdriver to pry it off anymore.
