12v battery test
Sleep7
Sam
new york new york
Mach E
Doctor
How long does it take for the dealership to test your 12V battery?
Holy Driver
Lars
Germany
Mustang Mach-E RWD SR
the question is what is the test?
ack154
2023 Mach-E GT PE
You don't need the dealership to test your battery. AutoZone, Advance Auto or wherever can test it for you for free. Should take about 2 minutes. Or you could buy a tester yourself.
CoyoteMach
Gary
2025 Mach E, 2024 Mustang
,Retired
It will take longer to remove the panels covering the battery than it will to conduct a test. (Unless you have modified the panels for battery jump access).
tbrumleve
Tom
Oregon, USA
Somewhere between thirty minutes and three months. Depends on how many plumbuses they need to use. The amount of available schleem will determine how many plumbus they can make.
There are multiple methods used to test a car battery. One requirement is that the battery be charged enough to test. If it is low, then it may sit on the machine for an hour or more being charged until it has enough charge to be tested.
I had a dying battery (6 years old) in my F-150. Fully charged it, then drove to Walmart to get it tested (and likely replaced). 20 min in they told me it needed a few hours to charge to be tested, so I said nope, I just did that so it is bad, put in a new one.
ICE vehicles get the entire charging system tested, which isn't necessary with an EV, but the battery needs enough charge to be tested.
Fordman
Frank
Austin Texas
2016 FORD EDGE, 1998 FORD EXPEDITION
Retired Ford Dealer
If you getting a warning and the battery is more than 3 years old, just get a new one,.
