2023 Mach E Rotor scoring
Rosanna
Wilmington North Carolina
2023 Ford Mach E GT Performance Edition
Had the car since last August. The car has 3,000 plus miles on it. Notice scoring on left rear rotor. We made an app. to have it looked at.
Anyone else notice that on their Mach E?
Ford Mustang Mach-E 2023 Mach E Rotor scoring Mach E rotor
Everyone else.
Get to speed. Shift to N, apply brakes gently. Shift to D, get to speed, repeat. After say 3 times, pull over somewhere and look at rotors.
Then, cancel appt.
LittleBittyRose
Rosanna
Everyone else.
Then, cancel appt.
Interesting. Shifting to neutral is better than turning off one pedal driving?
Turning off 1PD doesn't turn off regenerative braking.
Right. ALL MODES use blended braking, i.e. regen, then pads at the very end (or pads if you slam on the brakes). Rotors and pads get rust. Shifting to neutral turns off any regen, you get brake pads on rotors.
I do it about once a week or so, and after washing the car at home.
LittleBittyRose
Rosanna
Well we just a little bit of what you suggested and it is cleaner! We are going to do that some more!
Appreciate the suggestion! Thanks!?
We also just want to be sure it isn't something that we need to bring it in to check.
Highly doubt it's an issue. Lots of posts on this.
LittleBittyRose
Rosanna
Thanks! ?
