2023 MME GT
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 3
AngryMan
Living the good life
The Inflation Reduction act has a 30%/$1000 tax credit for chargers and/or 240 line install. I got $650 back when I installed my charger and line couple years ago.
BTW my box was on opposite side of house also. Adds costs but definitely doable
AngryMan
Just a thought . Earth Day is coming up and alot of charger makers offer discounts at that time .
silverelan
Seattle
Mill Creek here. I had a premium AWD standard range. When Ford dropped last week I took advantage and traded up. GT was only because of the great price. I don’t do badly on my trade either.
Haha, I’m just leaving Arena Sports in Mill Creek to head back to Seattle . Good job on the trade up to the GT
socalh2oskier
Jake
2022 Mach-E GT Performance Edition
Almost retired
I’ve had my car a week and still can’t get past the 220 range. I understand the car is still learning my driving behaviour? Will it get better in time/spring?
We have a '22 GTPE. Over 6,000 miles, we are averaging about 3.1 miles/kwh. Our range is usually around 240 at 90% charge. We live in the Phoenix area. We never use the heater. A/C doesn't seem to affect range very much. Our miles are mostly city driving. If we had heavy freeway driving, the range would be much less. On the freeway doing around 70-75 we get only around 2-2.5 miles/kwh.
david_quick
Bremerton WA
2023 Mach E GT
When I picked mine up in September I routinely got 3.5 miles / KW. It went downhill as temperatures cooled off and is running 2.5 now. The heat is always on right now.
Kind of wanting to see if it improves over the next couple months.
Probably. But it also depends on where you drive and how you drive, so nobody can really answer that for you.
AngryMan
I did exactly what you just did . Traded in my Select for a Gt . As I sat in car for first time even though it only had 10 miles on it I went into the menu and deleted the driving history.
Can't hurt !
Guest
Can't hurt !
I did the same so the car and I can bond haha
david_quick
Bremerton WA
2023 Mach E GT
I'm in Seattle, 43F outside right now and the numbers above are about what I see. However I'm charging and pre conditioning now and have on my GT:
I'm sure it will drop as soon as we get rolling but it's a nice guess I suppose.
I see 100% 270ish. In the garage.
Tcevwa
Tonya
Eatonville, Washington
2023 Mustang Mach E GT
We are
Ford Mustang Mach-E 2023 MME GT Screenshot_20240303-080906_FordPass
in Eatonville, Wa with chargepoint charger. The current temp is 37F. The car is in well insulated garage. We predominantly use home charging. I'm looking forward to the higher range this summer.
AngryMan
UPDATE....Theyve changed the tax credit
Ford Mustang Mach-E 2023 MME GT Screenshot 2024-03-04 at 9.57.51 AM
Arsenic17
Arsenic
Denver, CO
MME GT 2023 Vapor Blue
After 8K miles, I had a lifetime 3.3 mi/kWh average on my 2022 Premium 4X. This is in Colorado where our temperatures are often below freezing 4-6 months of the year and close to 100°F in mid-summer.
After about 500 miles on my 2023 GT only in winter, I am sitting at 2.8 mi/kWh. I expect lifetime my GT should get ~3.1 mi/kWh, but we'll see.
EPA rated range of my Premium was 277, while GT is 270.
Guest
More or less the same in Seattle
