2024 Gear Shift Knob Availability?
640k
Cincinnati
2024 MME GT
I feel like an idiot... Are these supposed to be relatively hard to install?. Mine came with rubber o-rings that don't seem to fit and I'm nervous to push these on top of the existing knobs because I feel like it's going to scrape all of the paint off, and if I end up hating these, I'm going to hate it even more if my stock knobs are damaged!
Nomad77888
Alan
Miami
2024 Ford mach-e
Yep, the rubber o-ring fit for the display knob but it didn't for the gear shift. I just pressed them in. They are made of plastic so I doubt they can do much damage.
640k
Cincinnati
2024 MME GT
Are you talking about the covers? Because mine are aluminum.
The stock knobs are plastic and almost certainly painted.
Nomad77888
Alan
Miami
2024 Ford mach-e
Sorry, you are correct. I just pressed them on the original knobs. I don't know if they damaged them or not. I just plan on leaving them on there. I don't see a reason to ever take them off.
640k
Cincinnati
2024 MME GT
Normally I would agree with you, but I have a screen protector on the main display and I'm not 100% certain the cutout will fit past the cover.
Nomad77888
Alan
Miami
2024 Ford mach-e
Hmm, that's a different problem...
nickff
Indiana
2024 Premium AWD Extended
It looks like the confusion here is we are talking about two different companies that make these dial covers/crowns. The ones I use and actually helped design with Kevin, are from his company 5 SPURS and they do fit the gear shift dial on the '24 model year Mach-E. I have personally installed them myself so I know they fit.
The EV-Vida dial covers/crowns are differently designed and do not fit over the slightly different '24 gear shifter dial. As Roy mentioned above, they are working on a version that will fit the '24's.
Mark, can the dials from 5 SPURS be removed without damaging the original dials?
markboris
Sonora, CA
Yes. Takes a little force to pull them up but there is no damage. You might have to clean off the gummy adhesive with some goo gone. ?
