A2Z or Lectron
BharathRajan
Bharath
MachE premium
New to MME. I own a GT and need suggestion on which Tesla adapter to buy. A2Z typhoon vs Lectron. Pl suggest.
Lectron Tesla Supercharger (NACS) to CCS Electric Vehicle Adapter - 500 Amps / 1,000V - Fast Charge Your CCS1 EV at Tesla Superchargers with Vortex Plug https://a.co/d/jeTTipg
There's been a lot of discussion of these on the Forum.
You can use the search function in the upper right of your screen. Search on either A2Z or Lectron.
You'll also find a discount code for A2Z.
You can also try this video:
imstriker
Matthew
Indianapolis
Tech
Hard to answer either or as I only have the A2Z. I'll just put my personal testimonial here that it is outstanding. Customer service was awesome, they went above and beyond. Adapter has served me well and finally made reliable road trips.
Bruboy
Bruce
HTX
2023 Mach E Premium, 2014 Mercedes-Benz CLS550
Semi-retired
A2Z Typhoon Pro is highly recommended. I do believe Lectron has reworked and improved theirs.
4sallypat
Pat
www.kudo-ume-farms.com
Network Tech
Agree - A2Z Typhoon is much easier to use than the OG.
I have both and they are built very well (solid).
Compare to the Ford adapter which is more plasticky, it's my backup adapter.
garyd9
Gary
Pittsburgh, PA (USA)
2023 Mach-E GT
I have the most recent design from Lectron and it works well.
For me, the choice was ordering the A2Z for a bit less money and waiting at least a month for it, or spending a bit more money and ordering the Lectron via Amazon and getting it the next day.
I've never been very patient.
Doug&Julie
Douglas
Beaverton, OR
2021 Mach-E Premium LR-RWD
Designer
I also have both (Lectron and A2Z Pro)...it's hard to pick one over the other. I had an easier time connecting and disconnecting the Lectron when I tested them. But I'll also say A2Z went above and beyond when my original adapter wouldn't work, and the new Pro works great. Whichever you choose, check the websites before buying on Amazon as they're likely cheaper!
This video doesn't really answer your question directly, but might be a help...if you're bored...
mdolan92869
Orange County, CA
Retired Software Engineer
If you end up looking at the A2Z Typhoon Pro, also look at getting the bundle with the Tesla destination adapter. You can get them both cheaper and I think you can use a discount code to get more off. A quick search found MACHEVLOG as a discount code.
A2Z's support is much better than Lectron's, not even close. They've done videocalls with people on the road at a charger when they've had issues. Often it's the CEO who talks with people.
The A2Z Typhoon Pro is $193.50 with discount code FORDFORUM. Using the dropdown menu to select the Stellar adapter for Tesla Destination chargers is only $67.50 more, a total discount of 20%, the highest possible discount. https://a2zevshop.com/products/nacs-ccs1?ref=Typhoon&variant=43186507579592
