Aftermarket 360 camera system add on?
MooSting
Earth
None
It's for security and the wifey's parking safety as I am planning to give her the MME in a few months
I have a select without the 360 also. I have found that when I click the "camera" button I get the rear view camera and the car with the front and back 'sensors' to tell you how close you are to things. Even though I can't see around my car the sensors see enough that I can park scary close to the wall in my garage 'blind'.
I find its plenty to be able to park.
Tngo23
Tngo23
Tony
Northern CA
22-GTPE, Lexus GS350 F Sport, Porsche 911 SC
Chilling
Well....Finally got it installed and so far i like very much.....I replaced the stock mirror with a mirror monitor combo, there are 4 cameras (front cam, left/right mirrors, rear cam) as planned with a Birdseye view.
See pics....
Ford Mustang Mach-E Aftermarket 360 camera system add on? 12221490-4FD2-4EF6-91DB-9E97769AD5D2
Ford Mustang Mach-E Aftermarket 360 camera system add on? 00FF539A-0836-45CF-8437-7AB383433E65
Ford Mustang Mach-E Aftermarket 360 camera system add on? 318588AA-EDD4-48A3-8C66-6240F6730098
Ford Mustang Mach-E Aftermarket 360 camera system add on? 70701CB9-2964-412A-9D4D-C45CCF3268AF
agdad
Derek
78155Ray
2020 Ford Edge
Uhhh Because I did not order my 360 package when I ordered my MME......
Obviously your WHY tells me you don't care for the added 360 cam system.....
To each his own my friend....
Ive got a 360 view
trutolife27
Bourbon Country.
If you intend to use it as something like Tesla's sentry mode, I think it will consume a lot of electricity. I heard Tesla's 720p cam (which is probably optimized a lot) takes 4-6kwh per day. I'd not stress the 12V battery that much given there are so many 'stop safely' issues. You may try to use an external battery but that barely holds this system for a day or two, and safer ones used for dashcams are freaking expensive.
takes about 25 miles of range a day so yes it does consume.
Mach1E
See pics....
Glad it worked out.
Am I seeing things or is the 360 view kinda wonky? I can’t tell what’s going on it that picture.
Tngo23
Tngo23
Tony
Northern CA
Chilling
Glad it worked out.
Nah, the pic is showing the front camera on the right & the left side the Birdseye view (up top)....Not wonky if you are not used to it......It shows the 360 view from above per se.....
Not in pic but when I signal left or right, the mirror triggers the left or right camera to display (left or right) side. Pretty cool to me but I still use my mirrors and turn my head for safety....
SpaceEVDriver
Planetary Science
Looks great!!!
I purchased a similar system like yours for my Tacoma. The screen on the mirror died on me shortly after the system was no longer returnable. I hope yours is better quality than mine.
I ended up wiring the cameras into my Tacoma's system screen, which has an RCA plug.
I'm sure the Mustang's camera system takes some similar input, if you do end up with a failed display in the mirror.
Tngo23
Tngo23
Tony
Northern CA
Chilling
Looks great!!!
Thx but unfortunately there isn't anything aftermarket for the MachE Sync4 system yet that has an RCA input to add or split the camera input. I could have waited for Naviks because when I called them, they are 90 days out at the time and I am not a patient person with car mods.....LOL ;)
SpaceEVDriver
Planetary Science
Did your system come with calibration targets and instructions for enabling the stitching of the 360-degree view?
Tngo23
Tngo23
Tony
Northern CA
Chilling
Yes....it took the shop a bit of time to calibrate it though
SpaceEVDriver
Planetary Science
Ah, okay. I had to build my own calibration targets and...well, overall it sounds like you got a better system than I did. I bought mine a few years ago, though.
Tngo23
Tngo23
Tony
Northern CA
Chilling
Overall, I am happy with this system and the mirror monitor is very clear, HD like resolution.....Hope it last for time (1-2 yrs) I have this Toy.....
