sammm99
Hello, i have ford mach e 2023
After 6 months of ownership, airbag light showed on screen, it started coming on and off regularly (it only goes off when i turn off the car not while it's on), i tried to figure out the pattern of it showing up but there wasn't, sometimes it disappears for a month and sometimes it's there for a couple days, i scanned the car and the code was B1404:13-28 i searched about it and it was related to driver seat airbag, after some digging i found similar issue about the circuit being open, i checked the cables under the seat and they were all fine and i didn't see any damage, but the light still show up, i tried unplugging it and then plug it again it disappeared for a but then reapeared again, after that i scanned it with forscan, and thr airbag resistance was 4 and i unplugged it and replugged it again tightly, the resistance went back to 2 ( it should be 1.8-2.5 ) , it disappeared for a bit then after couple days it went up again, i went to a garage and they advised changing the airbag itself ( p.s there is no dealership in my country )
I have some question:
1- what caused it to show up after 6 months of ownership, i had no accidents, do they become faulty on their own?
2- can i replace the airbag itself without changing the whole seat? I don't want to mess up with the seat
3- if the airbag itself is broken then shouldn't the light be on all the time?
4- what can i check for other than under the seat? Are there other accessible locations where i can reach connection areas?
Any other recommendations?
