All buttons on driver side door stopped working!
BBUSTARD
GARNET VALLEY, PA
Mach E
Anyone else have problem where all buttons on the drivers door just stopped working? Windows can close with the app fortunately, but no clue what happened. Dealer knows less than we do about the car so this should be fun visit.
Neil4Real
There's a technical service bulletin. Is it even the unlock code buttons don't light up/work? Try opening your back door first then the driver door, see if that works. If it does, you probably need to have the bulletin completed.
ahg
Arthur
Crofton, Maryland
2021 Mach E 4x 2014 Accord V6
Since it is all the buttons it might be a bad connection.
timbop
I believe that disconnecting the 12 volt battery and reconnecting it has helped others; the problem is in the control module and that has reset it for some
BBUSTARD
BBUSTARD
GARNET VALLEY, PA
Mach E
Update. It started working again. Windows,locks and all. Still going to let Ford look at it when doing windshield recall.
