- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat ER
One of the interesting things to me is that EVs, made by the same company, can have totally different battery components or algorithms. This January has been abnormally cold, and I've been watching my vehicles and charging. Both vehicles are prevented from charging from 11AM to 7PM, my peak rate period.
Currently is 5 degrees outside, ceiling sensor measures 25 degrees. My vehicles are in my garage, which is not heated or insulated, but is part of my house, so it has 2 interior walls (ceiling is not insulated and there is not a room above 80% of it.
The Mach-E, which was used yesterday for a 15 mile grocery run that ended around 3:30, charged between 7PM and 8:36PM to 90%. This morning, at 5:36AM, it pulled 1.63kWh to warm the battery for 20 minutes.
The Lightning, which hasn't been used since 1/20, last warmed the battery on 1/21 from 9:16AM to 9:34AM, pulling 1.47kWh.
They sit side by side, and are plugged into identical chargers.
Over the past weeks, I have looked to see what's been happening for battery warming. Note that the Mach-E is used more often, so it is possible that on some days the battery was warmed enough that it didn't see the need to warm overnight. Of course this morning's warming seems to be the opposite of that point...
Mach-E:
1/1 - 1.55kWh
1/20 - 1.79kWh
1/23 - 1.63kWh
Lightning:
12/12 - 1.22 kWh
12/15 - 1.26kWh
1/16 - 0.6kWh
1/20 - 1.28kWh
1/21 = 1.47kWh
Mach-E:
1/1 - 1.55kWh
1/20 - 1.79kWh
1/23 - 1.63kWh
Lightning:
12/12 - 1.22 kWh
12/15 - 1.26kWh
1/16 - 0.6kWh
1/20 - 1.28kWh
1/21 = 1.47kWh
