Best time to charge ?
Ruthie B
Ruth
North Carolina
2023 Premium
laundry service
Is it better to plug in and charge at home as soon as you get home, while the battery is still warm from driving, or plug in and wait an hour or 2 for off-peak evening rates ?
My electric rates are 14 cents before 6 pm and 9 cents after 6 pm. Saving a couple of bucks on 45 - 57 kwh is not a deal breaker. I charge every 3 days.
E90alex
Seattle, WA
‘25 MME GT
To the car it doesn’t really matter. But since you have TOU rates might as well wait until it’s cheaper at night.
it’s also better to charge every day unless you barely drive anywhere and you’ve only used a few % of charge.
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Usually it's best to charge later at night when the temps are cooler and the rates are less. The battery does not need to cool off, it doesn't get hot.
I read somewhere in a post that it is better to wait an hour or so after driving before plugging in.
I wish I could find the thread.
I believe that it said "to let it stabilize", whatever that means.
Sikkun
2023 Mach E
Manual says best to wait several hours and reasoning it gives it “to cool”.
Ford Mustang Mach-E Best time to charge ? IMG_6363
Teslaeata
Nottingham, England, UK
Only ever charged when I’m ready to do it and then to the level of charge that suits me which, historically at home, was virtually always to 100%.
No detriment to HVB which is at 93.5%SoH after 51mths & 119,000 miles.
So, worry ye not!
Manual is not correct, battery temp does not appreciably increase while driving if you monitor it. That is likely a copy/paste from a hybrid manual, those do warm up their batteries quite a bit.
YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
I plug in when I get home, but I have the EVSE configured to not enable charging until later when the rates go down. (I can manually enable the charging if I need to.)
I also only charge to 70% as this is plenty for my daily needs (20-30%).
