- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
The stability control and ABS can compensate for wheel spin and hydroplaning to the extent that is possible via available grip. Torque will be instantly cut if wheel spin is detected (it won’t keep the throttle in and spin wheels like old cars). It is a modern advanced system designed to be safe, and will automatically cut out if conditions are too adverse.I’m actually surprised that the program would allow you to use BC in the rain. Using any kind of cruise control in rainy conditions is inherently dangerous because of wheel spin. Granted some cars nowadays can correct for wheel spin it just makes sense to drive yourself in the rain.
Insurance companies love to deny claims for people that use driving assists in inclement weather conditions.
BlueCruise works just fine in light to moderate rain, as always you should be paying attention and ready to take over at any moment. I personally only disconnect BlueCruise in the heaviest rainstorms (red on radar) where there is significant hydroplaning risk (if it hadn’t already disabled itself). And because you want to slow down in heavy rain anyways. It should be based on driver judgement, but I would not make the statement that BlueCruise is unsafe to use in any rain—only with heavy rain.
I’ve also used BlueCruise in snow, but use is limited because the lines typically get covered fairly quickly during a storm. ABS will be automatically used to slow down or stop if the wheels lose grip, even if your foot isn’t on the brake pedal. I have a lot of experience using it, know its limitations, and when to take over.
