Brain fog
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
Today my Mach e forgot its charge settings. When I plugged it in it started charging. My walk away lock also did not work. It seems it doesn’t know where it is as it still has an entry for charging to 80% at the time specified.
When I go to navigation it can find my location but when I go to charging locations it will not find my location.
Mia there a way to reset everything?
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
I also had the head lights staying on for a long time even though I had auto delay off. Yesterday I did the turn of lights thing and it fixed that.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Charge the MME for an hour.
Unplug it and go to the FordPass app charging log.
Select the last charge and designate as HOME.
Set it up as Charge per Charging Schedule. Set the time to a schedule.
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
Now walk away lock does not work. I turned it off and shut down then turned it back on, still not works.
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
I managed to get it to find my location and set it up again. In the car. The walkway lock still doesn’t work.
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
It’s like there is a memory leak that screws everything up that you have to reboot to fix it. Kinda like having to reboot windows every week or so.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Can’t help you there. When mine fails I lock with the app or the codes on the door post (7-8 & 9-0 both pushed, I think). Maybe updates are doing it.
