Cannot Re-Enable Connected Services After Turning Off
Machee-veli
2021 Mach e
Has anyone experienced the following problem? If connected services are turned off, from the settings menu while in the vehicle, then the system glitches out and won't let you re-enable it?. What happens with me is the a window pops up that says you have to change it in settings to turn it back on, then when I click the settings button on the screen, nothing happens and it won't actually let me turn connected services back on.
The only way I can get connected services back is to do a reset of the whole system.
Does anyone know when this will be fixed or if there is a way to get the system to function as it actually should?
Thanks
Logal727
C
Thanks
Keep trying, there's a known bug where the Connected Services menu won't populate, but it comes back every so often. Apparently it's a server issue.
Yes, eventually it will show up. Keep trying periodically over the next few days.
Logal727
C
Kinda wild this hasn't been fixed yet if its server side, is there something they are waiting on?
Machee-veli
Machee-veli
2021 Mach e
Glad its not just my issue then, I suppose. Something so basic needs to be fixed asap. Thats crazy
Who knows, I reported it in May. It's possible 5.1.1 fixes it but I'm still seeing some odd behavior where it initially doesn't want to load. It's my opinion it's a server issue because it breaks for everyone at the same time, but some people may not believe that and think it's a module software thing.
Ford Motor Company
Official Ford Account
Thanks
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this concern? Thank you!
