Can't Auto-Update Clock
flapjake314
NYC
Mach-E Select AWD
I have a weird clock situation going on...
So the clock on the car is correct because I manually set it correctly. However, the "auto update" option is off and it cannot be turned on. Over time the clock actually gets less and less accurate as a result. When I click the slider to turn on, it turns off on its own after 1 second.
I don't know if it's the same issue but my FordPass is 5 hours behind. If I update my FordPass to be the newest possible update, it still says "last updated 5 hours ago". I know it's the newest because I'll do a drive, see my % battery on the car, go to FordPass, it's the old %, refresh FordPass, it's the new %, but it says "updated 5 hours ago"
Anyone else have this, any guess what's going on ?
Edit: It's not always 5 hours but it often is. Right now it's doing 7 -shrug-
Maybe no GPS signal, park outside with a clear view of the sky and try again. Otherwise do a SYNC reboot and try.
flapjake314
NYC
Mach-E Select AWD
wait what the clock update is via GPS?
my GPS is actually broken right now, maybe that's why the clock doesn't work then?
have tried sync reboots
