Can't turn on OTAs (Auto Update) - 23 Select
Milly-E
Texas
2023 Mach-E Select
New to Mach-E, I bought this car a month ago and have wanted to turn on automatic updates. When I go to the update section, all it does is stay on loading. In the Ford app, I can toggle it on, but then it turns itself back off. Am I going to have to take it in to the dealership to get this fixed? I heard something about disconnecting the 12v battery, but just want some tips/thoughts. Thanks!
DeusEx
New York
2023.5 Mach-E Premium ER AWD
Pull the 12v and if that works, you're good. If it doesn't, you need to go to the dealer.
Pull the 21-22 fuse and if that works you're good. Otherwise, you'll next need to try the 12v pull. If that fails, off to the dealer you go.
I typically do the 12v pull to "reboot" all the modules in the car cause if that fails I know I have larger issues I cannot fix myself. Saves me time and helps with troubleshooting.
rugedraw
Javier
Miami, FL
Auto Sales
Disconnect the 12v battery in the frunk for 20 minutes and then try checking for updates again.
Milly-E
Texas
2023 Mach-E Select
Thanks for the responses! I'll try it out
SmoothJ
2023 Ford Mach-E GTPE
I had the same thing happen to me when I picked up a new to me 2023 MME. As others have mentioned, disconnect the battery for around 15 mintues.
I tried the fuse, and they are really wedged in there. So you need to get a fuse puller or you might lose the fuse (which happened to me). Howver that personally didn't work for me.
rugedraw
Javier
Miami, FL
Auto Sales
For this specific issue, I recommend the battery pull and not just the fuse.
