Car scanner app not showing some information
redgrandam
Jay
Southwestern Ontario, Canada
2023 Mach E Select
I’ve used other apps before for other cars like this, but I just installed Car Scanner to get details on battery temps and charging etc.
There are three boxes that don’t show any information. They remain blank all the time but everything else works and updates perfectly.
Anyone have any idea why? I just got the car, so it’s a 2023 Select with LFP.
Attached is a screen shot, the ones with the X are the ones that don’t work.
thanks!
Ford Mustang Mach-E Car scanner app not showing some information IMG_0510
thanks!
what ODB2 unit do you use?
I have no problems with Viecar, but I've seen a couple others that don't seem to send all data.
also, I have noticed that mine works perfectly when AndroidAuto is off, but doesn't seem to connect properly with Android Auto enabled. which is a real bummer since the only app I have found that MIGHT work to mirror my phone display to center screen needs android auto to work.
correction.... mine is no longer connecting correctly at all. it might be the 2/18/24 update of CarScanner, or it might have been my experimenting with AA and screen2auto
thanks!
Oh you have a 2024? Those might not be supported yet. Or it could be the OBD adapter.
redgrandam
Jay
2023 Mach E Select
Hmm. I had CarPlay on I can try with it off. It’s a Bluetooth reader that I’ve had for a while, LElink or something like that. I’ve used it a bunch with my Bolt and it always sent all data. But I’ve had it a few years so not sure.
It’s a 2023. It’s possible they changed some things and it isn’t supported. That’s what I’m wondering…
OK. FYI your signature says 2024 Mach-E. My guess is you're using an adapter that isn't fast enough.
alexgorod
Alex
DBA
Not all ODB2s support EVs, I had to return one because I didn't pay attention when I got it in Amazon
redgrandam
Jay
2023 Mach E Select
Oops. Thanks. I fixed that.
Ok thanks for the suggestion. I’ll see if I can find one that is better quality that isn’t too expensive.
i am noticing that there was a recent update to both AA, and to CarScanner.... I cannot get carscanner to connect to my phone at all anymore.... somebody broke something.
worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
Not noticing any problems for my setup.
Adapter: vLinker MC+
CarScanner Pro
Ford Mustang Mach-E Car scanner app not showing some information CarScanner Information
2023 Select (MFD: 12/22):
06/15/23: 4.2.4
06/30/23: 4.2.5
06/30/23: Customer Satisfaction Program 21B36
07/13/23: 23-PU0314-DCM-LAT
07/15/23: 23-PU0105-DC-CHG2
09/25/23: PowerUp 5.1.1
10/18/23: PowerUp 6.1.0
11/06/23: PowerUp 6.2.0
11/06/23: 23-PU1103-NAT-VCE
12/08/23: PowerUp 6.3.0
12/14/23: PowerUp 6.7 **** INCOMPLETE ****
02/20/24: 23-PU0722-DC-CHG3
02/22/24: 24-PU0102-SVD-FX
redgrandam
Jay
2023 Mach E Select
Ok I just figured it out. I just had to customize the screen a bit. The ones that are there by default are the wrong sensors (at least for this model year). So I just looked through the sensor list while charging and replaced the ones that weren’t working.
worachj
Eagan, Mn USA
Just curious, which profile were you using? Wouldn't think the Mach-E & Lightning profile would have the wrong sensors.
redgrandam
Jay
2023 Mach E Select
Just the default after selecting the Mach E profile. Possible I didn’t set the layout up right… I’m new to the app so not totally sure. But I definitely selected the right sensor profile.
Adventureboy
Ontario
CarScanner Pro
06/15/23: 4.2.4
06/30/23: 4.2.5
I use the same setup. Works for me so far.
